Re: B275 compression leak around injector
Posted by JimB2 on May 28, 2008 at 17:14:37 from (99.241.179.24):
In Reply to: B275 compression leak around injector posted by markinab on May 28, 2008 at 16:10:03:
Mark, caseih.com parts:
B275 Engine Page 025 item 30 4 710383R1 GASKET GASKET, pre-combustion chamber, lower.
It has been 40 years since I had an injector out of a B414 but I recall the gasket being a copper compression ring like was on old spark plugs before the tapered plug was invented.
JimB
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
