Re: Super M Gears Grinding?
Posted by Andrew Kappers on May 28, 2008 at 17:23:25 from (207.118.216.168):
In Reply to: Super M Gears Grinding? posted by Smith1000 on May 27, 2008 at 18:47:25:
The problem is speed shifting. If you shift while the tractor is still moving, the gears will usually grind. Usually this is only shifting up. Going from 3 to 2 for example. When you shift down 4 to 5, they usually slip together pretty easily. Many farmers speed shifted over the years and ended up having transmission problems. Gears arent cheap and involve quite a little work to replace. If you arent in a hurry, the time it takes to let the tractor stop and shift could save you some money down the road.
