Posted by Red Mist on May 28, 2008 at 17:28:29 from (67.142.130.26):
In Reply to: farmall h steering gear posted by donald schnupper on May 28, 2008 at 17:02:25:
I would not worry about the up and down play. Pull the cotter pin on the sector gear nut, hit the nut with am impact wrench. It is a taper fit. When you know it is good and tight, align the holes and reinstall the cotter pin and don't worry about the up and down play.
If you absolutely cannot get it out of your mind, try various spacers under the sector gear until there is almost no play. However, if you get too thick of a spacer, then you won't be able to tighten the sector gear on the taper tighly enough without binding up the steering. Personally, I would not worry about it. mike
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
