Re: h timing belt
Posted by Janicholson on May 28, 2008 at 19:06:40 from (64.83.197.176):
In Reply to: h timing belt posted by daniel g on May 28, 2008 at 18:44:52:
If it is loose on the hub, just use a brass drift to punch it in the right direction.
It is not a timing belt, it is a fan belt.
It should be about an inch of slak when pushed hard with your thumb. Tight is bad. JimN
