Re: farmall h steering gear
Posted by Bob M on May 28, 2008 at 19:10:44 from (69.205.114.144):
In Reply to: Re: farmall h steering gear posted by donald schnupper on May 28, 2008 at 18:46:36:
Nope!
The thrust bearing is a large diameter annular contact ball bearing located just above the pivot shaft flange.
It is replaced by dropping the pivot shaft out of the fixed bolster. It normally comes down with the pivot shaft as it is lowered.
Other than causing the worm and gear to not line up correctly a failed thrust bearing has no effect on either part.
