Posted by glennster on May 29, 2008 at 08:28:57 from (76.224.27.162):
In Reply to: engine overhauling posted by charley123 on May 29, 2008 at 08:19:01:
a good machine shop will check the head to see if it needs surfacing. if you put a warped head back on, more than likely it will leak. you do need a valve spring compressor to get the valves back together. with out the proper knowledge, skill and equipment, it is real easy to ruin a head. generally heads will run from 100 on up and over 500 depending on whats wrong. i have a hot rod machine shop that does work for me, they do a great job, and get a kick out of the old motors.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
