Re: Woods L59 Belt twists
Posted by Bob Kerr on May 29, 2008 at 09:01:04 from (64.12.116.73):
In Reply to: Woods L59 Belt twists posted by Chad504 on May 29, 2008 at 08:44:29:
I have a L59 on a kubota so it may be different, but the twist looked strange on mine too, but has worked fine. I did have a problem with belt rolling over on the back, but that was due to worn out bearings and pulleys, new pulleys and bearings solved that. Ate 2 belts before I found it though and they are pricey at $80 each and looked like they sat on the shelf since 1978! Apparently they are "woods only" belt for kubota. Check those pulleys! If they have been wearing in the bottom of the grove replace them now and if the belt rolls over once it will be junk even if you put it back on right!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
