Re: Generator charging rate--part 2
Posted by Bob M on May 29, 2008 at 09:41:18 from (151.190.254.108):
In Reply to: Re: Generator charging rate--part 2 posted by John T Yo Bob n Jim on May 29, 2008 at 07:21:31:
Hey John T - you are correct about the two resistors' configuration!
The field resistor is a flat wound affair wound onto a flat, bakelite(?) bobbin/terminal assembly.
The headlight dimmer OTOH is a half-dozen or so loops of heavier wire in a self-supporting coil configuration. Further, from the factory the dimmer coil was originally wrapped in (gasp!) asbestos insulation - which is usually long gone 60 years later.
Regarding field resistance values and wattages I know a #194 lamp (4 - 5 ohms) will work as a substitute resistor because in a jam I tried it once! It'll cause the generator to max out at 3 - 4 amps - enough to fire the ignition and leave an amp or two left over to float charge the battery (ideal for long runs in hot weather).
...Bob M
