If there was no electricity going to it, and it still spun, the drive is in need of replacement. There is a new clutch style drive at the caseih dealer that is much better than the old style. If the copper pisec you refer to is the contact that is located on the side of the starter motor casing, and is just a "bump" of copper, it is originally intended to be a switch contact, and not be connected to with a cable. In this case, it may have had threads put in it to hold a cable with your non stock setup. A motor repair shop can install a new stud through the case with the ability to put an official nut on the real threads. It is possible to silver solder an adapter bolt to the stud you have, but W/O taking it all the way apart, the heat will melt the insulator. Best of luck, JimN
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
