Re: Super M, regular M and H Oil Pump
Posted by Theman on May 29, 2008 at 11:18:36 from (65.248.77.5):
In Reply to: Super M, regular M and H Oil Pump posted by charley123 on May 29, 2008 at 08:25:49:
After several attempts to build good pressure in my '47 H by increasing the bypass spring tension, I finally found wear on the shaft just above the gear set. To remove the shaft for inspection, punch the pin out of the driver gear and pull the shaft out of the bottom of the housing. Shaft wear is easy to spot. I believe the service manual gives specs for the gear clearance and end play. If things are too worn, get another pump.
