Haywood: Take the shift lever off at the base. (3 bolts) Then take a big screwdriver and move the rails all to neutral position. If the end of shift lever is not the size of the notch in one rail, then build it up with welding. Keeping in mind the size of that notch in rail grind the welding until it shifts smooth.
What happens with these, end of shift lever gets worn and slips out of notch without moving rail to neutral. Your lucky you didn't put it in 2nd or 3rd and drop the clutch at full throttle, it will go in those gears while still in 4th or 5th, and the weakest gear breaks.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
