Re: engine overhauling
Posted by ScottyHOMEy on May 29, 2008 at 18:18:48 from (70.105.241.102):
In Reply to: Re: engine overhauling posted by garytomaszewski on May 29, 2008 at 17:20:40:
Sorry, gary, I was a little vague in my post on the distinction between learning and having the eqipment to plane a head versus the question of how to remove a valve.
To be more clear . . .
I don't think that a board where I have seen fifty+ posts over the last several years explaining to a fellow (usually going back into his first motor rebuild when he fired it up and had oil pressure problems) how to reface an obscure but important part in the guts of an oil pump on a pane of glass should be a place where somebody doesn't get shut down by being told that, if he has to ask how, he shouldn't be trying to remove a valve.
