An 06-86 series has two hydrolic pumps. One is low pressure and operates the steering, brakes, and T/A, and feeds the high pressure pump. It is located on the left side of the tractor on the speed transmission housing behind the multiple control valve(MCV). The high pressure pump is also on the left side but is behind a plate near the bottom of the trans housing just in front of the of the axal. A weak high pressure pump will usually cause low flow at the remotes and decreased lifting of the three point. If the low pressure pump goes bad you loose steering, brakes and the clutches in the T/A will not lock up and make the tractor move.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
