Re: Woods L59 Belt twists
Posted by Hugh MacKay on May 29, 2008 at 19:04:35 from (209.226.106.80):
In Reply to: Re: Woods L59 Belt twists posted by Haas on May 29, 2008 at 18:29:30:
Haas: My mower is an RM59 on a Super A, there are two L59 mowers near me on offset tractors, and in both cases they have one V idler and one flat idler. Same as mine except the flat idler is on the opposite side and those mowers are belted backwards compared to mine. All three mowers are driven by the belt pulley gear box.
I've seen two V idlers used when mower is driven by PTO shaft.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
