On that 12 volt tractor you can EITHER use a full true (some call internally ballasted) coil or else a 6 volt coil with an external series voltage dropping (12 to 6) Ballast Resistor.
Take note on coil labels, a 12 volt may read "12 volts" or "12 volts NOT for use with external ballast" while a 6 volt may read "6 volts" or "12 volts requires external ballast" which is in reality only a 6 volt coil and requires the ballast just like it says.
If you alrerady have a good 6 volt coil n wanna use it the ballast (Keith has ya covered in ohms n watts values) is a cheap addition but if you dont have any coil at all prob cheaper to just buy a 12 volt coil no ballast required
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
