Re: Cub stops running
Posted by mkirsch on May 30, 2008 at 09:18:29 from (64.80.110.50):
In Reply to: Cub stops running posted by John Halford on May 30, 2008 at 06:23:23:
Assuming you have a 12V battery here...
A coil is a coil. The one from NAPA with built in resistance will work fine. You won't get a "genuine" coil from a CaseIH dealer, anyway. It'll be the same one as Napa sells, only more expensive in most cases. Plus if you get an old timer behind the counter you'll get an argument over which coil you really need, and will probably wind up going home with a 6V coil.
If you get a 12V coil with internal resistance, the proper location for the resistor is the trash bin. The resistor is not stock, and does not have a "proper location" on the tractor. It's used to reduce the voltage to the coil on a 12V conversion. Cubs were 6V until the late 1960s.
