Re: Super A - Metal Strap
Posted by ScottyHOMEy on May 30, 2008 at 09:34:50 from (70.105.241.102):
In Reply to: Super A - Metal Strap posted by SuperA-Tx on May 30, 2008 at 08:34:49:
Yep. Actually that strap should have been bent at the corners. Bending the corners up was to keep the bolt heads from backing out.
