Sounds like your dad didn't add a ballast resistor ahead of the existing 6 volt coil. On a steady diet of 12 volts the old 6 volt coil will overheat and quit sparking after a few minutes.
Cheapest solution is to wire in a ballast resistor into the primary before the coil. A resistor for any 60's era Chrysler vehicle works great. (Autozone #AL795 or equivalent - about $8)
Tip: Check the breaker points too! If they've run very long on 12 volts they're very likely burned and should be replaced.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
