Re: Firing up an H
Posted by old on May 30, 2008 at 19:09:57 from (4.244.219.181):
In Reply to: Firing up an H posted by rnicholas on May 30, 2008 at 17:40:28:
Well since I buy a lot of tractors like what you have this is what I do. First I fill the cylinders with tranny fluid. Let it sit a few days. Be sure to put the plugs back in till the next part. Pull the plugs back out and then see if it will spin over. DO NOT turn the ignition on just spin the engine over to clear the cylinders. Do a tune up and also check to oil for water. If you find no water then try to start it up. If it starts run it 10-15 minutes change the oils and then put it to work. I've done this about 100 times in the last 10 years and has been working well
