Posted by GordoSD on May 30, 2008 at 19:12:03 from (66.115.200.140):
In Reply to: Firing up an H posted by rnicholas on May 30, 2008 at 17:40:28:
Buy an owners manual. Crack the rear transmission plug and see how much water, gunk is in there. (If you get the engine running.) Go ahead and drop the pan and get 15 years of sludge out of there BEFORE you crank it! Remove the valve cover and clean the sludge out of there, BEFORE you crank it. First oil fill 4 qts CHEAP oil and 1 qt diesel fuel. Run at idle for 15 minutes and drain and refill with good oil. Get a new 6 volt battery. Clean all the terminals form battery to starter to switch.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
