Re: farmall H 12volt resistor for coil
Posted by TheDurk on May 30, 2008 at 21:15:15 from (72.76.191.149):
In Reply to: farmall H 12volt resistor for coil posted by the tractor vet on May 29, 2008 at 14:38:45:
El Toro said: (quoted from post at 11:45:20 05/30/08) Napa has a 12 volt coil P/N IC14SB with a built-in resistor for about $18.00. Their ballast resistor is P/N ECHICR13 for $14.00. Hal
And the coil you use WITH the external resistor is P/N IC13.
