Re: B414- Whitworth bolts?
Posted by MJ in the UK on May 31, 2008 at 05:02:02 from (86.144.134.49):
In Reply to: B414- Whitworth bolts? posted by zzztime on May 30, 2008 at 08:29:32:
They use UNC and UNF threads. MJ
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
