Re: Farmall A won't start
Posted by old on May 31, 2008 at 08:57:20 from (4.244.217.115):
In Reply to: Re: Farmall A won't start posted by Tom Campbell on May 31, 2008 at 08:16:25:
What happens if you pull the choke?? Does it die or run better?? If it runs better then your carb probably is clogged up and need to be rebuilt. If it has and adjustable main jet you might open it up an 1/8 turn at a time to see if that helps. Also your spark needs to be a nice blue/white spark and be able to jump a gap of about 1/4 inch or it will run weak also
