Posted by Janicholson on May 31, 2008 at 09:30:24 from (66.173.50.157):
In Reply to: Generator - Regulator posted by Leon Torkelson on May 31, 2008 at 09:01:31:
Probably needs more analysis. Is the wire going to the gen from reg #10ga wire? Is the system charging normally when running?
If the wire is thin, it needs to be #10. But if the wire is thick or thin, the regulator is the gate keeper on current flow when stopped. The points of the cutout are open while stopped, and close when the gen starts producing enough voltage to close them. The cutout relay in the regulator must be open when the tractor stops. If it does not, it will discharge through the generator. The generator may have shorted internally, causing it to be more of a current draw, but I would replace the regulator first. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
