Re: cam- magneto timing
Posted by Bob on May 31, 2008 at 13:22:35 from (69.178.228.68):
In Reply to: cam- magneto timing posted by poorfarmall 1 on May 31, 2008 at 12:54:40:
The SIMPLE solution...
ASSUMING the crankshaft-camshaft timing has not been disturbed:
NO timing marks are needed...
The slot in the mag drive will be HORIZONTAL when #1 cylinder is @ TDC.
That will take a couple of tries, due to the helical gears, but that's ALL that's needed.
