Re: farmall H driveshaft removal
Posted by Roger46 on May 31, 2008 at 18:57:43 from (69.58.159.75):
In Reply to: farmall H driveshaft removal posted by Narrowfarm on May 31, 2008 at 15:47:21:
John, I don't think you can get the drive shaft out without taking the pressure plate loose. I have never tried to take it out that way, but I don't think there is enough space in the coupling to allow the shaft to pull completely out of the pilot bearing and spline in the clutch plate. If you take the pressure plate bolts out you may be able to tip it enough to remove the shaft. Is there some reason you are taking out the drive shaft? Roger
