Re: farmall H driveshaft removal
Posted by Janicholson on May 31, 2008 at 19:22:03 from (64.83.197.176):
In Reply to: farmall H driveshaft removal posted by Narrowfarm on May 31, 2008 at 15:47:21:
There is a way. It requires taking 3 equally spaced bolts out of the Pressure plate, then putting them into three holes on the rdge of the PP. this compresses the pp and allows just enough wiggle room to get the shaft out. JimN
