yenaled: Number one and probably most important in keep cost in line, is you tractor already equipped with a factory rear rockshaft? Once you have that it's quite simple. Being a hi clear model it may present a few problems in that hitch linkage will need to have a different lifting range the a regular 140. I have built quite a few 3 point hitches for regular clearence SA, 100, 130 and 140, however with these being roughly 6" higher off ground, geometry is going to be a bit different. You want it to be able to set implements on the ground yet lift them about same height in relation to ground as regular clearence tractor.
If you wish send me an e mail. I can park my 140 on 6" blocks with implement attached, then quote you exactly what changes you need to make it work decent. I suspect it will take about 3" longer lower link, but until I set this up, I cant be certain. Measure the height of PTO shaft from ground as well as clearence under front axle. I don't remember the exact clearence difference, plus my 140 has over size tires so factory specs wouldn't be great help. To give you good advice, I just want to be sure my tractor is same ground clearence as yours when I have it on blocks for measuring.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
