Re: farmall H driveshaft removal
Posted by Narrowfarm on June 01, 2008 at 03:26:19 from (69.113.66.237):
In Reply to: farmall H driveshaft removal posted by Narrowfarm on May 31, 2008 at 15:47:21:
Thanks guys,i got the drive shaft out with your advice from this site!!! i am replacing the two seals in the tranny end and the one in the belly pump.Might as well replace the throw out bearing also as that seems a little bit loose. I removed a ton of grease from the tranny area. I was able to get all the seals out last night. thanks again.........john
