Pull the plugs out and then fill the cylinders with ATF in the cylinders and let it sit over night. Then try to turn it over the next day. Oh and before you try the ATF in see if you can turn it over. It could have water, oil or gas in a cylinder and hyd locking on you
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
