Re: Spliting tractor apart
Posted by Paul in MN on June 01, 2008 at 13:25:52 from (71.210.157.191):
In Reply to: Spliting tractor apart posted by Ric , Florida on June 01, 2008 at 08:27:40:
Ric,
Is this tractor the row crop version or the utility? It is very unusual to need to replace the flywheel. What diagnostic symptoms lead you to believe that the flywheel is needing to be replaced? I can understand problems with the teeth missing on the starter ring gear, or problems with the clutch. But in both cases, the flywheel is either machined flat by a shop or the ring gear is replaced. And yes, the tractor needs to be split to do either.
If it is the taller row crop Farmall, be sure to have proper support for the engine so that it doesn't fall sideways. Do not depend on a rolling floor jack, especially if it is a narrow front tractor. Take the time to build a splitting support stand. Use heavier metal than you imagine that you need. In fact, you will be betting your life on the stability of the stand you build.
If the tractor has a wide front, then you can control the possible sideways fall of the engine section by cutting oak wedges out of about 2" thick stock. Make the wedges about 7" long, about 2 1/2" thick on one end and taper to about 1/2" thick on the other end. Firmly hammer each wedge between the front axle tube and the front bolster frame casting. Now the engine can not pivot on the axle pin.
Some guys do a split by stationary support of the engine and then rolling the tranny and rear end away from the clutch bell housing. I prefer to keep the rear end stationary, and roll the engine section forward. It is less weight to move and seems to make reassembly easier when you are getting the clutch splines to line up.
If you have never done a split, I would recommend that you seek the help of an experienced "old timer". This is no job for a first time amateur. If were are close I would be glad to help you through the process, but I really suspect by your handle that you are in Florida, and I am in Minnesota.
My e-mail is open if you want to talk one-on-one. If so, forward me your telephone number, as I type awful slow.
Paul in MN
Today's Featured Article - The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one ... [Read Article]
