Posted by Red Mist on June 01, 2008 at 17:49:24 from (67.142.130.18):
In Reply to: 1950 FARMALL M posted by HIGHLANDERSCOTT on June 01, 2008 at 17:43:51:
HIGHLANDERSCOTT said: (quoted from post at 17:43:51 06/01/08) Hi Guys, Need to remove front section of steering shaft, to remove radiator. How do I go about this. Factory wide front end still needs to come off. Then I can get to rad. bolts, correct? thanx for the info.
To remove front section of steering shaft.... 1) Remove grill; 2) Remove plug in front of steering box; 3) Disconnect u-joint between front and rear steering shaft; 4) Turn front section of steering shaft out through the front of the steering box. mike
Today's Featured Article - Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
