Posted by glennster on June 01, 2008 at 17:51:40 from (68.60.242.156):
In Reply to: 1950 FARMALL M posted by HIGHLANDERSCOTT on June 01, 2008 at 17:43:51:
to remove the steerig shaft, you need disconnect the shaft up near the tem and oil pressure gauge. there should be a u-joint there with a bolt. take the bolt out and spray up the shaft with penetrating oil. if it has power steering, ie char-lynn, there is a roll pin you need to drive out. next unscrew the big pipe plug cap at the front of the top of the steering bolster, once out the shaft will unscrew out of there. you should be able to get the two lower mounting bolts for the radiator out without dropping the front axle. yours may still have the mud shield under there. you also need to unbolt the cooling fan shroud from the radiator, and set it back toward the engine to get the radiator to clear .
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
