Re: Generator - Regulator
Posted by Leon Torkelson on June 01, 2008 at 17:56:06 from (74.47.157.100):
In Reply to: Generator - Regulator posted by Leon Torkelson on May 31, 2008 at 09:01:31:
OK I hooked everything back up and cut some grass. I managed to kill the engine, when I tried to start it the battery was to weak to do so. As I was running it looked like there was a small discharge showing on the amp guage but it was so small it was hard to tell if it was or not, it was. I tried to polorize the regulator and all I got were sparks, I disconnected all wires and belt from the generator then I used jumpers cables to see if the gen would run like a motor, it does. Along about this time I finally realize the generator is also the starting motor. So at this point I am gussing that I have a bad regulator.
