Re: leaking valve guides
Posted by Steven f/AZ on June 01, 2008 at 18:32:13 from (24.121.155.84):
In Reply to: leaking valve guides posted by c1802362 on June 01, 2008 at 18:27:16:
I would start with a compression check to be sure the rings are good...
Worn valve guides usually give a puff of smoke at start-up and as they get progressively worse will continue blue smoke at any time while running. The smoke may go away under a load due to the increased temperature being able to make for a more complete burn of the oil.
Is it smoking excessively? Is it using oil? Does it blow oil out the exhaust that gets on you and/or the tractor?
Personally, I wouldn't let a few puffs of blue smoke cause me to tear a good running engine down unless their is excessive oil usage or a mess being made...
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
