Re: leaking valve guides
Posted by Janicholson on June 01, 2008 at 19:09:37 from (64.83.197.176):
In Reply to: leaking valve guides posted by c1802362 on June 01, 2008 at 18:27:16:
I like Perfect circle type valve seals. d
D?
o what Steven indicates, and if good, go with seals, they can be installed W/O removing the head. Idle and part throttle conditions cause high vacuum. high vac on the intake valves suck hard on the stem to guide area, causing more noticible smoke then. going down a long hill in fifth will make it smoke the most. JimN
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
