Posted by Janicholson on June 02, 2008 at 07:11:03 from (199.17.61.7):
In Reply to: 806D electrical posted by Filo Coats on June 02, 2008 at 07:00:38:
Simple checks. 1} while running at 1/2 or better RPM, put a volt meter across the battery/s. It should read between 14.2, and 14.7 volts. If it does, it is charging. 2} check the batteries for dead cells. (unless sealed and no caps) using a specific gravity tester. should be 1175, or better when charged. if cells are different more than 10% or so, the battery is poor. 3} With the engine off, remove a battery cable and check voltage from the terminal to the connector you removed. There should be less than .5 volts there. If more, there is a voltage leak. Disconnect components one at a time, and check for the leak (then replace if it makes no difference) so it doesn't become a wiring disaster. Good luck, JimN
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
