Re: 560 value
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by rodger on March 12, 2000 at 20:25:07 from (63.13.63.51):
In Reply to: 560 value posted by Colt on March 12, 2000 at 18:50:03:
Depending upon how much 'slop' is in some of its typical wear points, (steering, front axle, lift linkage, how elongated the drawbar pin hole is, etc.) I've seen these run between 2000 and 4000.I've seen otherwise good looking 560's with a bad TA, bring as low as 1200 and I've seen them go as high as 4500. You may have to check with some dealers in your geographic region also.
Post A Followup
: Re: Re: 560 value
