Posted by Janicholson on June 02, 2008 at 14:41:19 from (64.83.197.176):
In Reply to: w4 carb settings posted by lost in ontario on June 02, 2008 at 03:29:37:
Lowest screw is a load screw. It adjusts fuel air at full load. It should be 1/8 to 1/4 turn out from lean best running. Screw to front top is idle speed. See specs. Other top screw is idle mix, Depending on whether your tractor is early. or in the 53 category, it may be lean or rich, in or out, set it to best running. JimN
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
