Re: carb. setting for super c
Posted by ScottyHOMEy on June 02, 2008 at 20:46:22 from (70.105.241.102):
In Reply to: carb. setting for super c posted by David Crowell on June 02, 2008 at 20:27:16:
Most likely you have only one fuel screw, and that will be for the low idle fuel adjustment. It's possible you have a second one for load fuel. I either case, a good rule of thumb is to bottom it out gently, then back it out 1-1/2 turns. That will usually get it running, and you can adjust from there.
