Re: Farmall M engine problem, need advice
Posted by Red Mist on June 03, 2008 at 04:33:19 from (72.171.0.141):
In Reply to: Farmall M engine problem, need advice posted by Jim R on June 02, 2008 at 21:37:54:
Jim R said: (quoted from post at 21:37:54 06/02/08) Is there any kind of engine additive that I shoud try to maybe help it to straighten out?
Yes, there are products you can try. In the marine business, we used one by Evinrude - Johnson called "Engine Tuner", the primary purpose of which is to free up stuck rings and loosen carbon deposits. It works very well (- much better than injecting water while running). You spray it into the carb air intake while the engine is at fast idle. After 3-4 good long shots of it, you shut the engine down with it, let it sit for maybe two hours, then fire it up again and run it for a few minutes to clear the engine. The stuff will make a lot of smoke and kill every misquito for miles around, but it sure helps free up rings in a carboned up engine and boosts compression also.
I'm sure there are similar products at your local auto parts store. Good luck. mike
