Re: What differences are there between a 1466 and a1566?
Posted by mkirsch on June 03, 2008 at 10:24:44 from (64.80.110.50):
In Reply to: What differences are there between a 1466 and a1566? posted by NDS on June 03, 2008 at 08:57:26:
One fewer gear in the speed transmission allowed IH to make the remaining gears heavier to deal with the additional horsepower.
Planetary final drives, and heavier axles were added as well.
The classic 4-speed, 2-range, TA transmission was only designed for the horsepower that an 806 could put out, around 95HP. It just wasn't built to take 140+ HP, and there were a lot of transmission problems on the '66 series because of it. Wasn't as bad as the 560 fiasco, but then again, there were a lot fewer '66 series tractors than '60 series.
I guess part of the justification for having fewer gears was, the tractor has so much horsepower, you just bull your way through instead of matching ground speed to available power.
