Re: Fan belt
Posted by RJ-Wi. on June 03, 2008 at 14:38:47 from (198.56.12.237):
In Reply to: Fan belt posted by hauling H on June 03, 2008 at 14:20:17:
Spray some WD-40 on the threads of the fan pulley.This pulley is adjustable. Loosen the locknut on the setscrew and place flat tipped screwdriver in slot and back out the setscrew. Then take a punch and hammer to strike the moveable half of the pulley. The pulley has a square block on it to strike. Once the pulley is loosened enough you can slip the belt off the lower pulley and then pull it over the fan blades one at a time till it is off. Reverse this to install new one. Good luck.
