Re: 130 carbeurator problem
Posted by Daniel H. on June 03, 2008 at 16:12:20 from (66.226.34.159):
In Reply to: 130 carbeurator problem posted by tcmeehan12086 on June 03, 2008 at 12:03:42:
The part you need is the throttle shaft. It is available from Case-IH for about $35.00. Some rebuilt kits include the shaft so you might try a TISCO dealer and get out cheaper. The rod is for the governor adjustment, not the idle. The idle is controlled by the stop screw in the part you broke. I did the same thing on a Super A.
