FARMALL M RADIATOR
Posted by SCOTT SWAIN on June 03, 2008 at 17:58:05 from (71.13.90.132):
GOT THE RAD. OUT TONIGHT. DEFINITELY HAD TO REMOVE FRONT END. I'M GOING TO DRILL/MACHINE HOLES IN STEEL PLATE THAT HOLD FRONT ON SO I CAN ACCESS THE NUTS IF I EVER NEED TO AGAIN. DO YOU THINK THIS WILL IN ANY WAY WEAKEN MOUNTING PLATE? ALSO, ANYTHING ELSE I SHOULD CHECK OR LOOK INTO WHILE TRACTOR IS EXPOSED THIS FAR? THANX SCOTT
