Re: Farmall 100 surges for gas
Posted by chad from michigan on June 04, 2008 at 02:38:24 from (151.163.2.8):
In Reply to: Re: Farmall 100 surges for gas posted by old on June 03, 2008 at 21:09:14:
Is the adjustable main jet coming out of the top of the carb at an angle? I think we adjusted that and it helped once then slide back into howe it is running. Is there a start point like 1-1/2 turns out from seated? I will play with it next time I put the disk on. Thanks guys
Chad
