Re: Wheel Weights for IH 340 Uility
Posted by Randy in NE on June 04, 2008 at 05:09:23 from (204.124.192.31):
In Reply to: Wheel Weights for IH 340 Uility posted by LeRoy D on June 03, 2008 at 21:34:49:
The parts manual shows the split type wheel weights. They have the same bolt pattern as the one piece so I would think that any of the wheel weights for a C on up through the 66 series would work. They may not pass muster with the correctness police but if all that you are after is ballast then any of them should fit.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
