Re: Baling with SH at an Idle
Posted by Steven f/AZ on June 04, 2008 at 06:13:18 from (24.121.155.84):
In Reply to: Baling with SH at an Idle posted by VA Gasman on June 04, 2008 at 04:28:57:
I wouldn't run less than 1/4 throttle for extended periods... As long as you aren't lugging the engine down you should be OK, but throttle up once in a while to clear everything out, if the engine isn't running up to temperature you will get cylinder wash from unburned fuel at a slow speed.
