Re: IH #8 Plow frogs -vs Plow shins
Posted by Grizzybear on June 04, 2008 at 08:26:36 from (12.130.109.185):
In Reply to: Re: IH #8 Plow frogs -vs Plow shins posted by Tom Wiindsor on June 04, 2008 at 08:10:06:
Plow frogs are what you bolt the shin to. This actually bolts to the plow beam with 2 or 3 bolts
Shins are a wear piece that "Cuts " the ground at the inside of the furrow. Below the shin is the landslide. Other than the share + the moldboard that is all there is to a plow bottom
