Re: Small engine oil.........
Posted by Wayne from MN on June 04, 2008 at 09:22:47 from (66.228.243.49):
In Reply to: Small engine oil......... posted by Dellbertt on June 04, 2008 at 05:45:13:
Non-detergent oil is really only good for a non-combustion type situation; an air compressor for example.
Do the manufacturers put non-detergent oil in at the factory? I do not know of any.
Today's oils are far superior to yesteryears so following the original owner's manual on an antique can be misleading as to what oil to use.
